For Sale 75/78-series Troopy OEM lock & key set
SNLC
OCD
Supporting Vendor
Boise - Idaho
Website
www.snlandcruisers.com
  1. 70 Series
This is the full set for double fuel tanks. Ignition barrel, x2 fuel doors, x2 front doors, x1 rear door, spare tire lock and glove box door lock. ALL on the same OEM Toyota key. Ignition barrel is 1990-2015-ish.
$300 + shipping.
Cheers
PM sent.
Apologies for the late replay, we are busy and I needed to take the following pics for explanation.
I am not sure pre-1990, there are also some differences between 1990-2008 which is what the lock & key set is from. You will need to compare your ignition cylinder as well as the mount for it on the column. This ignition does not have a “glow” selection either. The rest of the kit is plug and play but the ignition cylinder is what a person needs to check.
Here are two different column ignition cylinder mounts.
Compare yours to this one.
Cheers
If this will work on my '93 HZJ75 Troopy (which it sounds like it will) I will take it. Consider it sold! Let me know next steps, please.
(assuming no tax and shipping is included and or reasonable?)
I have this set and it works for my 1993 HZJ77. That being said, still want to remove your ignition cylinder (it is not difficult to do this) and compare with the photos in this thread to be sure.
