For Sale 72 FJ40 w/ 396BBC, H55F, 6", lots more
Long story short: Had this rig since 2008, drove as my daily for 2 years then moved back home to Colorado for 6 months, and abruptly moved to Chicago, hence Cruiser has been in storage for the last 3 years. Last started up in January when I was back in town and ran fine (will need a carb adjustment and new batteries along with the usual freshening up. Truck is still garaged in Colorado and I've realized I won't move back anytime soon, thus am putting back on the market. Has a CA title (never changed plates when I got to CO) and has current California Non-Op registration.
First the bad: basically just some minor body stuff. Has some bondo on both fenders (previous owner), little bit on the front of the hood and I think a bit under the gunmetal on the quarters(havn't ever pulled it off or looked to closley). Additionally the body is rattlecan black, over the 3 year old rattle can camo which is over the stock forest green after a little sand down. Basically the rig is fully built mechanically and doesn't need anything further on that aspect. It's meant to be driven and not a trailer queen, but that siad it has a pretty respectable body, hardtop in good condition save for less than perfect seals, and hard half doors and full doors (not yet painted to match). I can get pictures or answer questions. Additionally there is one mechanical problem I'm aware of, the Ebrake is hydraulic (line-lock) and I believe a valve is sticking as at low speeds when your hard on the brakes the Ebrake has been wanting to stay on. Below is an incomplete parts list.
72 Toyota Landcruiser FJ40,
-396 Chevy Big Block motor. Bored to 406 (.030 over)
-Forged rods and aftermarket pop top pistons, SRP bolts if I remember right.
-Hooker Coated Headers
-Holley Truck Avenger Carb,
-Moroso Heads (Oval ports)
-Edelbrock intake Manifold
- MSD ignition module and coil.
-Crane Cam (unsure of grind)
-7 Quart Aluminum oil pan
- Griffin Q-rad Aluminum Radiator 19”x26”
-3.5” Stainless exhaust with flowmaster.
-Saginaw 800 Bow power steering conversion with matching pump
-Dual Optima Red top setup, stored in battery boxes next to rear seats
-Steel cage for rear.
-35” BFG’s with full size spare (90% tread on all) mounted on 15" black rock crawlers.
-Ramsey 8K Winch
-Hella lights mounted to bumper
-Second pair of lights mounted up high, and to 2 spotter lights in back.
-Hitch,
-Heavy Duty Hi lift jack mounted to the rear bumper (custom front and rear bumpers with D-rings and an ammo box and cooler rack on back. Has Hitch built in as well. Tied into the frame so you can jack from the bumper.
-Hard Top, Bikini top, Hard Half doors and Hard full doors.
-4.88” gears.
-Warn Manual Locking Hubs.
-Axles have 1.3” Cr Mo shafts.
-Auburn Limited slip in the front and Detroit mechanical locker in the rear.
-Full skids on T-case.
-Tranny is a Toyota H55f Heavy duty 5spd manual with o/d imported by Man-a-fre and installed by them (previous owner lifted in Thousand Oaks CA). Has the attached T-case. Attached to the Big block with an advanced adapters kit. Start it up in 2nd around town.
-Painless Wiring Fuse Block.
-Confer Back seat with storage underneath (forward facing with belts).
-4 Point Harnesses on the front seats..
-About 6” of lift. 4" from Downey springs, two from a Man-A-Fre anti inversion rear shackle reversal. The truck does not have a spring over rides fairly nice on the road before getting a bit jittery over 80mph
-Recovery gear (tree saver, snatch block, tons of tow straps and D rings, and gloves,
-Front disc conversion with willow calipers and slotted rotors.
-18 gallon main tank, and 22 gallon second fuel tank with electric Walboro? pumps.
-Gauges- stock speed/ fuel (switches over for both tanks), etc, tack on a GM steering column, 3 box with water, oil pressure and volts mounted up high on the dash.[/SIZE
Price is basically the motor and tranny build cost with the rest free, I just need to get some cash to pay down some loans. I can take more pics, just send your email. Don't know the mileage on the chassis, I think it's 110K. Motor was rebuilt by previous owner 20K ago, but I don't have receipts.
$10K
Bump. Price drop to $11.5K. Rig probably puts out 400hp/450lb ft/lbs. Will put some pictures of the motor and drivetrain as well as the hardtop and doors up tomorrow when I get a chance to get them from the garage.
I can see them on my pc at work and mac at home so not sure if that's the case all around. Also just found a bikini top for it. If anyone needs hi res pictures I can take whatever you need and email.
Bump. Got laid off and need to sell, I'm moving
to Colorado and would like to get rid of this week. Price
drop to 10.5k unless I find a ride for it to Colorado.
Bump: Back up for Sale in Boulder CO
Looking for $10K. FJ currently has a hardtop on it. It's been in storage in my parents garage in Boulder for the past few months and I'm going back to school in Chicago starting in April, so need to sell for tuition. Hate to sell this, but I need the cash and would rather not store it for a few years.
Note: it has a heater, but currently not connected. The BBC keeps it plenty warm, but i should be a quick job to heat it up. I can show the rigs most Sundays, but I work 6 days a week otherwise.
More pictures- Additionally I think the Carb needs a rejet after bringing her back from California for CO altitudes. It's hasn't been driven safe for a spin around the block every three weeks to keep it fresh since August.
Working on it, it's in my parents garage an hour away and I'm working 15 hour days currently, so alas no pics till maybe this weekend. Don't really want to sell this rig, but would rather avaiod as much studen loan debt as possible.
Wow, what a beast! Good luck with the sale
Bump this. I ended up keeping a while back and storing in my parents Garage. I'm going home for the holidays and would like to sell this to pay for tuition. Truck has been in storage since I brought it back from California in the September 2010, it's been exercised, but currently has fluids drained. Would need a gentle going thru, and a carb adjustment for the altitude. The heater is not currently hooked up (have in a box, it was only driven in California) and the the hydraulic E-brake needs to be adjusted
Great rig mechanically, body is decent, it's originally forest green, was rattle canned camo by the previous owner and I sprayed it in black afterwards. Definatly a rig designed to be used and not a show truck, but I tried to price based on the body condition.
I'll be with the Cruiser in Boulder, Colorado from December 11th-January 6th to show/complete transaction. Cruiser will include everything listed, and some spare axle parts/other parts (hardtop, bikini top, 2 sets or doors etc). Currently Registered CA Non-op as of 3 months ago, which for California guys this is Smog exempt. I'll post undercarriage pocs when I return to CO.
