'71 Headlight Wiring Trouble
IF turn signals are working then the rear chassis harness wiring is all correct. If you have a meter, verify that the GW wire coming from the brake to the turn signal switch has +12V when the brakes are applied. If it does then take the turn signal switch apart and verify that there is a jumper wire on the back of the PC board. This wire is what feeds the brake light signal to the two brake lights.
If it doesn't have +12V then start checking fuses and wiring for the brake light circuit. Don't rule out a bad brake light switch switch even if it is new!
Thanks--someone suggested hot-wiring the brake switch to see if the lights light. Is this wise (or will it just blow a fuse)?
You can unplug the brake light switch and jumper across the two female bullet connectors from the harness to see if the brakes light work. If they do: Bad Brake Light Switch.
If they don't then apply +12V to one of the harness side GW wires and try it, if nothing apply +12V to the other GW wire. One of them should get you brake lights IF the jumper is on your turn signal switch PC board as mentioned above.
Thanks all that replied--finally figured out the brake lights! I had spliced the front and rear turn signal wires together when I had had the '74 turn signal switch installed (due to trying to follow the color scheme for wiring), and I had just happened to have plugged them into the front connectors (there being two sets of GO and GY wires on the '69 switch), rather than the rear. Once I unspliced and got them connected correctly, the brake lights, turn signals, and parking lights all worked in sync.
Now, onto reverse lights...:bounce::bounce:
Should I bother trying to fix/re-solder the connection wire on my brake light switch (which broke directly off due to long-term rust), or should I just get a new one (in case anyone has ever fixed one)?
Had the same issue w/ my brake sw. Was able to resolder the connection-but got a new SW from BENO just in case my soldering skills weren't good--so far, the new sw is still in the box, just waiting----
BENO? (been using SOR in my first year of rehabbing due to their discount)
