Thanks for the update guys. And the referral.
Sweet rig too!
Sweet rig too!
It is in the footwell area of the third row, under the renogy battery. It is wired to the battery in the back drivers side and I put the control switch in the spot where the third row control buttons were in the far back. So to use it I open the back and the hose connector is right there.Where’d you install the compressor? Torn between finding a place to hard mount it or just put the compressor in a box.
My 700H Overtrail is finally ready for some long trips.
After removing the third row it took me some time to sort out a Drawer and Fridge rack system for the back of the vehicle. Not being able to remove the second-row seats I had to find a way to make maximum use of the cargo space in the back. I worked with Air Down Gear Up in Colorado to create a system which I am very happy with. Pictures follow. Some highlights. They designed their own brackets and created a new solid floor over over the battery using the stock attachment points where the 3rd row seat bolted to the vehicle. The system is then mounted to that using every bit of available space. The build is solid with ZERO noise or rattles even on rough washboard. A metal fridge rack allowed me to mount two Renogy solid state batteries in front of the Fridge to power the fridge and other accessories. The pull-out trays under each drawer provide the working space I was used to in my 100 series. It is not a tail gate but goes a long way to fill the need. The quality and attention to detail is exceptional. View attachment 4111173View attachment 4111175View attachment 4111176View attachment 4111177View attachment 4111178
