For Sale 70 Series Full Floater, 5 Speed, and more
Enderby BC
Need the space in my shop and could use the cash for other things so cleaning out and getting rid of a lot of my parts supply.
I have a Full Floater that came from a HZJ75 mine truck. It has e-brake, limited slip differential and factory disk brakes. I understand these are hard to find but coming from a mine truck I'm asking $800
I also have from a HZJ75 a H55F transmission. It has the crossmember with the rubber mount. The ends of the crossmember where it attaches to the frame were cut off with a torch. It has the shifter and knob. Also attached is half of the split t-case. Although half a t-case is useless it have the transfer case linkage and front drive shaft still attached. Asking $800
For both $1450
That's it for now but I intend to add to this
bump and price drop.
700 each or 1200 for both.
Removed top plate on transmission to take a peek and it was clean inside and there was still gear oil in the bottom. Zero water inside and zero rust inside. Outside casing is rusty and spline has surface rust but can be cleaned up and will work fine.
