'70 FJ40 Rockcrawler FOR SALE
1970 FJ40 Landcruiser, Smog exempt, SB Chevy 350 w/quadrajet, SM420 transmission, 3 spd transfer case (with t-case saver), tilt wheel, saginaw power steering conversion, spring over axle conversion, 4 wheel disc brakes, Dana 44 front end (built by Dynatrack - cut and turned w/new front driveline), hi-steer kit w/heavy duty tie rod and drag link, ARB air lockers front and rear, York onboard air compressor w/holding tank and two extra fittings for compressor hose attachments(will run pnuematic air tools), aluminum oversized radiator w/custom shroud and fan, Brand new 35" Goodyear MTR's (less than 1000 miles) w/matching spare (never used), custom swing out tire carrier w/ice chest rack, full family cage (w/grab bars) welded to frame, custom sunbrella bikini top (you can drop down the windshield on the trail and still have coverage from sun), 4 pt harness seat belts, rear seat w/belts, tub lined with durabak coating, 4.11 gears w/fine spline pinion rear, Rancho RS9000 adjustable shocks, WARN 9000lb winch (never even spooled out or used), Optima battery, CD, CB, Grant GT steering wheel, poly fuel tank, hi-lift jack, fenders cut and trimmed for clearance, rock sliders, bucket seats, center console, NEW PARTS: ubolts (all axles), rear greasable shackles, all wheel bearings, brake lines (front), new master/slave cylinder (clutch), master cylinder (brakes), brake pads front and rear, motor has new edelbrock intake, water pump, (HEI) electronic ignition, quadrajet carburetor (great off-road carb), and exhaust system
If interested (916) 847-1546 or t.pointer@comcast.net
Asking price: $15,500
Located in Roseville, CA
