anyone done it? I was wonder how hard it would be to swap the dash and gauges out of a 62 and put in all 60 series gauges and dash. I would think most of the stuff would bolt up but I think the wiring might be a problem. any ideas???
lunyou said:i haven't done this or i probably don't even know what im talking about but shouldn't the 62 dash just swap into the 60 and vice versa? Brackets should be the same and everything, i would think.
lunyou
I'm thinking this is not the case. When I got my '84 FJ60 the PO had swapped FJ62 gauges into the stock FJ60 cluster. All the gauges are/were plug and play. So at the very least I can tell you with experience the gauges will swap...lowtideride said:yeah but the wiring is different...like where all the stuff plugs into the gauges...
So you also switched the wiring? hmm..I dont know if this will work because it would be a 62 wiring with a 60 dash and gauges..
zebrabeefj40 said:I'm thinking this is not the case. When I got my '84 FJ60 the PO had swapped FJ62 gauges into the stock FJ60 cluster. All the gauges are/were plug and play. So at the very least I can tell you with experience the gauges will swap...
I have no experience with the actual dash structural differences between the 60 and 62 though.
HTH,
Nick
Herbert said:Why? The FJ62 dash is of better ergonomics. E.g. The radio is mounted higher, so you don't have to take your eyes of the road as much. Also the feel and quality are improved. But most of all it is a matter of taste. I'm a graphic designer and I feel the FJ62 dash is of timeless design, while the FJ60 dash looks a bit outdated. The FJ62 dash design makes you feel you are driving a much bigger truck. But taste is nothing we can argue about![]()
lowtideride said:Haha, I am also a graphic designer and find the 60s dash much nicer...
I like just about everything about it, the 62 dash is too new looking for my taste...
graphic design has some laws to it but most of it is just personal taste and what catches your eye.
Plus i love the tan and brown set up the 60s comes in ( fav colors) I have it in my 60 and love it. So I would really like it in both trucks... Does the 62 ever come with the brown/tan?
kevinmrowland said:Hey lowtide, I'm with you, I'm an industrial designer, 60s dash rules, hands down.![]()
