60 Engine Oil Cooler question: (1 Viewer)
WSOPgold2012
MoxieMan
Front Range
part # 15710-61010
If leaking is it easy enough to swap out the rings or just replace?
Thanks
Vague question.
Yes, cooler body is easy to replace. Depends on where it's leaking if needs replace. If body is rusty mess, then yes. The 'Unions' or bolts that hold it on the block have O-rings and copper washers. Rings are available from Toyota. Washers NLA. Rings are easy to replace, if that's where it's leaking. Unions are NLA.
Vague question.
its a rusty mess.... going to grab a new OEM cooler.... have a source? thanks
Vague question.
Rusty mess?
Well, you can replace it, if it's getting thin in areas and prevent any future leaks, but I've seen worse... City Racer has an aftermarket one that's cheaper. Do the O rings while you're at it. Clean up the copper washers and the Unions (bolt with holes in 'em).
edit: Nevermind, sold out.
this: 15710-61010 GENUINE OEM OIL COOLER ASSY 1571061010 | eBay - https://www.ebay.com/itm/15710-61010-GENUINE-OEM-OIL-COOLER-ASSY-1571061010-/173099784025
from SHARJAH, EMIRATES, United Arab Emirates which is a lil skurrry or
After mkt from City Racer.
will there be a significant difference to spend $150 ish + for OEM?
Dunno. Never seen the CityRacer one. Maybe someone can chime in.
Vague question.
Thoughts on this used OEM cooler? Looks clean....
Looks good.
I put a used one on mine 10 yrs ago and no issues, long as it's sound
