For Sale 60/62 door window chrome pass side rear
g-man
Charlottesville VA
$40 each. right side rear door chrome trim/beltline/fuzzies. Front door SOLD
Is that off a 62? Seems like they should match for all 60 series.
Do you have all the plastic parts/clips that hold that in place? I need to replace driver's side.
EDIT.... I see you wrote RIGHT. I need left. thx
They are off of a 60 series right side. I believe the plastic tabs that hold them in are molded to the piece. I will double check. I think the trim is the same for the 62. I will check that too as I do have drivers side doors off 62 with trim on them.
I have a set of drivers side that are the same as pictured. They have white clips about an inch long they came off with the piece and are on the piece. I thought these were 62 doors because they have power windows and locks. this trim looks like it is original to the door so I am not sure that a 62 doesn't get chrome trim on the fuzzies. Do you want the drivers and drivers rear door fuzzies? Also interesting when I pulled the back piece off the black fuzzy weatherstrip stayed with the small glass. Look closely at the pic you will see the rear piece doesn't keep all the fuzzy when it meets the small back window that is fixed into position. I guess it is not fuzzy as the small back window is fixed position.
About 34 inches long, with a bunch of these white clips. PM wouldn't let me add the pic. I have to run, be back to you later today.
