Yeah I know IDI is a bit gay, I think it is definitely a limiting factor a lot of heat and energy is left in the pre combustion chamber. I do have a 1KD motor that I would like to make mechanical injection for.
The turbos I am using is the ones I have spare a T2554 for the primary and a GT2876R for the secondary. I will post a pic in the next few days I am making the manifold at the moment
Have you done the maths on turbo sizing?
A lot of 2.8's (3L) wore out cranks when turbocharged because the cranks weren't hard enough. It's torque that kills gearboxes. 300hp (222kw) at 4000rpm is 530Nm.
To get 530Nm with a BSFC (efficiency) of around 300g/kwh you'll need to inject around 110 cc/1000 shots (that's doable depending on your injection pump plunger size).
To burn that much fuel cleanly and safely (A/F 18:1) you'll need 45 lb/min of airflow. 600 CFM.
To fit that much air into a 3 litre engine with 80% VE and a decent intercooler you'll need about 45psi (PR 4).
I have a map for a 2009 GT2876R. It's close to tapped out at 45lb/min and you'll want to run it with a PR of about 2.5 to get decent efficiency from it. That pulls the little one down to a PR of 1.6
The turbo sizing I've only run one rpm on (because it's a full days work to do a complete engine rpm range) and that's 4000rpm for max power.
I've used a 0.86 housing on the big turbo and a 0.64 on the small.
Wastegate the big turbo to 22psi.
Wastegate the little turbo to 45psi (max boost).
Small turbo is generating 28kw of power. Big turbo is generating almost 46kw of power.
Your intercooler has to shed 55kw of heat to drop the intake temp to 60C.
Drive pressure should be around 63psi.
Net power around 187kw.
You can do better with a bigger big turbo. Especially on the turbine side. These two have turbines that are too close in flow numbers to work well in a compound set.
I haven't checked spool up. My preference is to go with a smaller small turbo. But that one shouldn't be horrible.
You'll need a decent sized air-filter with a good cold air feed.
Good luck.
