I scheduled an appointment for my 30,000 miles service for my 2006 LC, a bit higher than I hoped for.
Does that seem like a fair price to you guys?
this is what they will do:
Replace engine oil and oil filter
Rotate tires
Lubricate drive shaft bushing
Lubricate propeller shaft
Lubricate wheel bearings
Replace limited-slip differential oil, if equipped
Re-torque propeller shaft bolt
Replace engine air filter
Replace cabin air filter (if equipped) Inspect the following:
Active height control gas chamber
Automatic transmission fluid
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs 7
Drive shaft boots
Engine coolant 8
Exhaust pipes and mountings
Front differential oil (4WD)
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Radiator, condenser and/or intercooler
Rear differential oil
Steering gear box
Steering linkage and boots
Transfer case oil (4WD)
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Replace front differential oil (4WD)
Replace rear differential oil, including limited-slip
Replace transfer case oil (4WD)
Tighten nuts and bolts on chassis
Driving in Desert or On Dirt Roads
Rotate tires
Drive shaft boots
Engine coolant 8
Steering gear box
