$500 '68 fj40, looks complete...
Homer Glen, IL
Those jeeps can go through anything!
I kinda wanna get it
If I can turn the motor over at the crank, I bet it will run. At the worst I could sell it as a "running fj40" and get more $.
Im trying to get steffy to buy it and throw a 22re/a340f/duals in it and he might be able to tow it with the 4runner.
That thing is worth way more than $500.
if you flip the bezel right side up.
I got a 2F and 4 speed for whoever takes on the project.
I can't afford to keep the pig running let alone my other two Cruisers. Don't make me buy it.
Besides I just spent $600 on a 93 Mercury Crapi.
It's pretty close. The driveshafts are a little different length and you have to cut a hole in the trans cover if someone hasn't already.
I also have a 327, and a 4sp/split case and a 3sp, and 1FZ/343
I got whatever you need, mang.
I'm your pusher.
So, Steffy?
Did ya buy it?
Where are those pics?
why everybody got to be all up in my bizness???:flipoff2:
fj40 pictures by reign189 - Photobucket
Im on the fence about it. I have no experience with body work, so I have no clue what I would be getting myself into and Im definitely on a budget. Im having my fj40 "expert" coming over after work today to take a gander at it for a second opinion. 4rnr will be here about 4:30 so, I wont have any further updates til then.
going to look at it tonight. Bringing a battery just to see if it will turn over. Its sat for a long time so Im sure the carb is all gummed up. Ill post pics later
I hope you did not try to turn it over...you could actually do more harm than good...
If the frame and title are good, and have a place to keep it, everything else can be changed or fixed with a little money at a time, and lots of elbow grease. If you have someone with parts, then you are already on your way :beer:
did not try to turn it over last night. I thought I would give it a shot tonight. I wasnt going to run it. Just interested in seeing if it would turn over and could possibly run. Why dont you recommend trying to start it?
Cause it may siezed, or there may something in the cylinders. With the torque a starter puts out your likely to break or bend something.
Be sure to bring your breaker bar tonight. We will turn it at the crank to see if it rolls over easily....(hopefully, not too easily) Honestly there is no reason to even see if it will start. Its been sitting for "10+ years", it aint startin. At the most, if it turns, we can try to crank it to get a compression test. (I left my tester at home)
From the pics....I say you can't go wrong for $500.00
Wheel it...don't fix it
Body work sucks. That body work is not going to be a lot of fun. Not impossible. The 45swb was way worse, but it took me a lot of hours in a shop with a lot of equipment and the body on a rotisserie to get it looking goodish.
It looks like it would be fun to wheel and build slowly and not give a honey badger about body damage. Think Woody's raisin.
