4Runner brakes
Swanzey NH
Ok so the 4Runner failed inspection needs rotors and pads, parking brake not working.
I'm thinking about switching to vented rotors and IFS calipers.
Is the master cyl good enough or do I need a different one?
They said the PB cables were bad but I think it's just the bell cranks are
a bit stiff.
Front end gets pulled apart and I will be installing the new Marlin Crawler axle seals. Still have an oil leak on the motor that I have to find sometime too.
Have a nice day!
Lane
Hey Lane:
It's a relatively easy upgrade, get yourself some early 80's Cruiser rotors, and go with early 90's V6 calipers from a 4Runner. You'll need to trim your backing plates to get the calipers to fit, I trimmed mine waaay back to expose the rotor so rocks and crap can't get stuck in there:
Cut a notch in the brake line holder to make it easier to remove the calipers from now on:
If you're doing new knuckle wipers, get some of those Rock Rings from TrailGear, and new stainless bolts:
Top it all off with a V6 booster and 1" master cylinder:
Start saving your money now to upgrade the crappy rear drum brakes to discs.
Thanks Ken!
