What you need, One Safari Snorkel Head, Two 45 Degree angle PVC Adapters, 1 90 Degree PVC Adapter, One 6ft length of pipe, Grinder, Sawsall, Welder, Steel, Caulking
Here is what I have put together so Far for my Custom Snorkel Installation
More pics to follow as they come
First off you need to buy the Safari Snorkel Head, You can buy JUST the head for $80 Canadian. (Pricey I Know But its what makes the snorkel look good. and not a TOTAL Ghetto hack job)
After you take off your Fender, you will notice there is already a hole in the Frame leading to the air box, all you need to do is enlarge it a bit to fit both a 2" PVC Pipe and the Wire loom.
Cut a hole in the air box and fit the Pipe into the box
Big Pic: http://www.mudrunner.ca/snorkel/snorkel1.jpg
Heres a Pic Of the Piece that goes into the air box
Big Pic: http://www.mudrunner.ca/snorkel/snorkel_b.jpg
Attached to the 90* Elbow
Big Pic: http://www.mudrunner.ca/snorkel/snorkel_a.jpg
In to Air Box
Next mock the pipe up where you would like it, You will need to cut the outter part of the fender and weld a plate in. for strength.
Big Pic: http://www.mudrunner.ca/snorkel/snorkel2.jpg
Heres the Cut.. sorry bad pic
Big Pic: http://www.mudrunner.ca/snorkel/snorkel3.jpg
Heres the mock up of how the pipe will Run. THIS IS THE MOCK UP. you need to bend the pipe in order to get the fender lining back on.
Big Pic: http://www.mudrunner.ca/snorkel/snorkel5.jpg
Here's the PVC Pipe all bent and the piece that goes into the airbox attached
Big Pic: http://www.mudrunner.ca/snorkel/snorkel_e.jpg
Here is How I bent the PVC Pipe. I heated up the plastic with a torch, (Just keep turning the pipe, and bend it over an old rim.
Big Pic: http://www.mudrunner.ca/snorkel/snorkel_d.jpg
Next Cut a Hole in the Fender. THIS PART IS SCARY,
Big Pic: http://www.mudrunner.ca/snorkel/snorkel6.jpg
In to Air Box
