406 cruisers clubhouse resources
bozeman MT
I have an extra 95 fzj80 factory service manual and electrical service manual to lend as a general clubhouse resource. I also have some specialty tools if any one needs them. I have a 54mm nut socket, ball joint separator, bearing and race driver set(all needed for a front axle service on an 80) also an A/C manifold gauge set and vacuum pump. let me know if you need to borrow anything.
Great idea, Sam. I have a nutsert thread setter deal, mighty vac, lots of soldering stuff and the regular shop tools. Post up specialty tools that you might have!!
Great idea. Just ask what you need and I may have it...
I have FSManuals for 1990 FJ62 and 1994 FZJ80. The one for the 80 has extensive wiring diagrams.
I NEED HELP!!! Ha. Hey everyone. I am in desperate need of some ignition help. My 83 fj60 with a full desmog stopped giving me spark. I have a dui hei distributor pretty much new with about a thousand miles our less on it. I have tested every component I could think of. Even went as far as putting the original distributor with coil back in and still nothing. My poor girl won't give me an inch. If anyone had any thoughts or suggestions or wants to come over and figure this out with me I would be super grateful. Thanks guys
I am finally heading home after 30 years. Will be in the Flathead valley. Once I get all my crap moved I will be able to offer a tubing bender (1-3/4 die), notcher, press, welder and most shop tools. Bringing my slightly built 40 et al. Hope to catch y'all once I get settled.
where are you located?
just bumping this thread since it was mentioned at todays meeting. Post up what you have to contribute to help every one keep running!
Oh..I just got from Cruiser Outfitters the spring tension thingy to set bearing pre load per FSM. Also, a cool fan belt tension gauge.
