4" suspension kzj78
having trouble finding a 4" suspension lift for a kzj78
A lot of the good taller lift kits were made in Japan. Not sure if they are even being manufactured any longer. And of course there is the language and distance barrier. But you could look into it if you have some connections.
These guys in NZ have 75mm lifts. If you buy slightly heavier suspension but don't load the truck down, you'll probably get 100mm (4") out of it. Might be stiff tho. 4WDbits Home - https://www.4wdbits.co.nz/
I lucked upon some used Japanese 100mm lift springs locally to me for only $100! Turned out to be excellent springs. I still can't believe I got them.
These trucks are so awesome with taller lifts like this. But all the common manufacturers (OME, Dobinsons, Ironman, etc.) only make 2" lifts for them. It's frustrating.
Lucky guy
