alia176
I'd like to hear some suggestions on what to do in this situation. I have a 4.88 R&P set new to me (bought from a Mud member, uninstalled) two years ago. This is for the rear, no factory lockers. It appears as though this is a Motive gearset (package has no descriptions).
The run out on the ring gear is at .004" max. This makes the back lash tight in one spot and way too large in other spots. I spoke to a machine shop and they "claim" that they can make the ring gear true again. But I don't know what this would do to the heat treated metal. Shop charge is $50/hour and he thinks that it'll take less time than one hour.
random thoughts:
-returning to vendor is not an option
-not the seller's fault. It is what it is.
-I know Precision gears are awesome (have their set on the front)
-the ARB flange that this ring gear is mating too has an acceptable run out of .002" (ARB says this is ok.)
-yes, I filed the ring gear and the ARB flange before installing (4 times)
just like Zuk does.
-yes, the side adjusters are properly setup and tightened.
-yes, the carrier bearings are pressed in all the way.
-my 80 is part time (Tcase mod) so this R&P will see 100% of engine torque most of the time.
My previous 4.56's were fine on the same ARB air locker so that isn't an issue.
Ideas, suggestions?
Thanks.
random thoughts:
Ideas, suggestions?
Thanks.
