You can pickup used ones for a couple hundred bucks... the 4.3 is a very, very common motor. I'd say they last in the 200k range, depending on how you drive it. Most expire between 175k and 200k, according to S10 and Astro Van forums. At 20k miles per year, that's 10 years of daily driving. If your truck actually lasts that long (think of how much bodywork alone you'll have done in that time frame), a rebuild in 2017 will be pennies in comparison. I'd rather have 10 years of being happy and impressed at the mud pits/muddy trails I can get out of, the on-ramps that I can merge properly onto, the ability to pull a decent sized trailer, etc. The power will be well used and could help you avoid an accident, to boot.A 4.3 will be good for 150k-200k. They are pretty cheap and easy to rebuild. Get one and rebuild it and you will be set for a long time.
To be honest with ya, the Chev motor will never be a 'yota motor, but it definitely doesn't have any recognized reliability issues. The motor is stout and cheap (as with most domestic bits), though longevity doesn't appear to be quite as good. Realistically though, how many 22RE's are there lasting 300k miles that still have good compression, aren't burning any oil, etc?I considered the same swap... but decided I'd rather have a rebuilt and much more reliable 22R.
I have no problem with my truck being slow; its not meant to be fast. My T-case gives me plenty of power to do anything I want. I like keeping my truck light.
Furthermore if your truck ever goes out of country, like to australia, you won't ever find chevy parts. Or at least not as easily as you'll find Toyota parts.
W56 FTW (For The Win)!4 cylinder Toyota transmissions will not live behind a 4.3
(technically they will, but you'd have to drive them the same way as you did with the 22, who's gonna go that!)
I can take a picture of the engine bay of mine if you like. Aside from the crappy strut towers (that should be hoops), everything is really easy to get at, especially the spark plugs. If you do flood your motor, taking the plugs out now takes 10 minutes instead of 40, for instance.Furthermore, if something breaks out on the trail (and lets be honest here, something is more likely to break with a chevy swap) would you rather work on an engine you had to cram into the bay, or a nice, open, 4 cylinder cockpit?
I can assure you my rig hasn't been driven lightly (it gets driven HARD) and nothing, aside from stock birfields have broken so far. They were replaced with 27 spline longfields which have been holding up awesome.
If there's one bad thing I've heard about the motor, that'd probably be it. I don't/haven't had any problems with leaks, but only older motors that haven't been refreshed with new gaskets, I could definitely see it.Yep, the W56 is rated to 300 ft/lbs of torque.
Well, let me know how it goes, I know two guys that have done 4.3 swaps and they both say its a constant battle with oil leaks :/
Hrrmm, I haven't heard of any stories like that so far. I wonder if the gaskets weren't seated properly when everything was bolted back up... because that definitely isn't normal. I'd question the quality of gaskets/silicone used, as well as the assembly of the motor (properly cleaned, surfaces plained and even, etc).Both had literally *just* been rebuilt and started having that problem :/
There's a hell of a lot more GM Dealerships 'ere than Toyota Dealers.Furthermore if your truck ever goes out of country, like to australia, you won't ever find chevy parts. Or at least not as easily as you'll find Toyota parts.
Definitely good info to have, being a 4.3 owner! Thanks mateWhen I worked in a shop we did a LOT of intake manifold gaskets on 4.3's. They constantly needed oil cooler lines and manifold gaskets it seemed. We eventually started to torque them down a little tighter than suggested by the factory and we never had any come back.
