orangefj45
Supporting Vendor
Advance Adapters just released their latest offering for lower land cruiser gearing options; a 4-to-1 gear set for the split cases. right now, only the 38mm kit is available for bushing supported t-cases. within the next couple of months the 34mm version will foloow. asof now, there are no plans for the 38mm bearing supported gears so if you'd like to run these in your fj62 you'll need to change the main shaft to the fj60 counterpart.
the kit will consist of the entire gear set and installation will require machine work to the case halves to create clearance for the larger diameter low speed gear.
pricing has been set at $1550 retail. i will be running an introductary special here on mud for $1475. let me know if you're interested in a set...
i saw the prototype set in person at AA's facility two months ago. i will have that gear set here at the shop later this week at which point i will be installing them in a split case in one of my personal vehicles; vortec powered 80 with a 4L60E behind it on 35s.
i will be doing an install write-up in the hardcore section on here along with some pics as time permits.
here's a pic of the gear set itself.
tia
georg @ valley hybrids
tia
