3B vacuum pump oil hose
White Rock, Tx
Working on my Diesel42 turbo install and need to replace the ragged oil supply and return hoses for vacuum pump. All I can find is brake lines and not sure if a hydraulic hose would have ID large enough. What have yall done for replacing these 2. The 10mm supply and 14mm return banjo fittings can be found with 3an ends but I still cannot find any prefab hose with 3an ends except brake hoses again.
I cant confirm right now, but there's a strong chance the 2H hoses are a direct fit? Those hoses are readily available brand new from Toyota.. Two part numbers
Alternator oil return lineToyota90923-02089
Alternator oil feed lineToyota90923-02100
A check of Megazip for your 3B part numbers and a call to Toyota might show they are the same, or if not, that yours are also available..
3B Part Numbers below.. different, but the 2H hoses may well fit.
90923-02072
90923-02073
