Are there people running recentered hummer beadlocks and 37" tires on their 100 series?
Holly UNSPRUNG WEIGHT nightmare, Batman..
Why will you ever want to expose a vehicle is not made for such massive forces to them..??
I just want to learn..??
But please, find somebody to run a proper "finite element analysis" on the suspension components, pivots & attachments to the frame and the frame itself > Red No Bueno..
Ps: the two wheel vehicle holly grail is "Weightless" rotationals thingies but not only that but derailleurs, internal hubs, disc brakes on bicycles and final drives, sprockets whatever's is hanging of the "swingarm" on motorcycles.
The main issues, densers/heavier springs, shims, circuits, fluids, need for exponentially more heat dissipation, much stiffer structures, mountings, hangers, aka endless troubles.
I concur. In fact, I knew several guys in the 4Runner/Tacoma crowd running 37s on their IFS. And I can attest that the 100 series is built way stronger than those trucks.Because he wants to. It doesn't have to make sense to you for somebody to do what they want.
Comparing bicycles to 4 wheeled automotive is not anywhere in the same league. We weigh these things down with armor whereas the ammeter bicycle crowd spends $100 on a water bottle holder that is .5 grams lighter...
In reality, fitting 37s onto IFS will be a challenge but can be done. It's not the mainstream thing to do around here, and you'll want to lift it with a combination of suspension/body lift to achieve your end goal. Running HMMV 37s won't be easy as you'll have interference into the body, when flexing especially in the front. If you're looking for a turnkey setup with off the shelf parts for 37s, the 80 series is the way.
Comparing bicycles to 4 wheeled automotive is not anywhere in the same league. We weigh these things down with armor whereas the amateur bicycle crowd spends $100 on a water bottle holder that is .5 grams lighter...
