33x12.50r18 on a 2000 uzj100?
Wamego, KS
So I have one slightly bent wheel that balances fairly well on my rear axle that doesn't cause any issues placed on the rear axle, and my spare is worse off than that one.
I have come across 6 tundra steel wheels for $100.00 that I am planning on purchasing.
What are your opinions on fitment with the stock offset and that wide of a tire? From what I have researched they will rub the UCA. Is that correct? So I would have to run wheel spacers if I went with that wide of a tire?
Thank you.
No first hand experience, but from what I have researched width is the issue with these trucks. 275mm-285mm is fine and 295mm has borderline rubbing issues. Your 12.5" = 315mm so I would expect rubbing with stock offset, not sure if the UCA or inner fender or ??. There are a few people running 315/75R16 tires on the 100, maybe take a look at some of those threads.
Thanks for the direction, didn't even think to do that!
