neowulf said:i need the complete kit i can't do it my self.
I want the "pre-bent-bolt-on-system" if u know what i'm thinking about.
3"or bigger, 4" stainles steel would be great!
EnDLeSS said:Little Tech Tip:
If you decided to run ' 3 or larger you will loose so much of your bottom end and with that so much flows you will also burn gas so quick I suggest that not good things to do.If you looking for rumble sounds why dont you get the custom cat back and one of the them i recommend the Borla XR1. Even one of top mods TwinTurbo LC80 i've ever seen recommend no more than 2.75 piping.
I've changed my exhaust system 3x so i just share with you here little.
3x exhaust sytem replacement was - early '98 Remus, '00 Borla cat back & '02 Bowlish Hi-Polish Stainless steel Dual system cat back until now.
HZJ60 Guy said:You wont loose a damn thing with that turbo sitting in front of the exhaust! Ive added 3-4-5" exhausts to many turbo diesels. Cummins, Toyota, Volkswagen. There has been zero loss of power!
TB
