3-link front on FJ80
bustanutley said:
A center limiting strap helps you climb, it keeps the front from unloading, and can also help in side hilling
true. However, I've been where he's at, and I can say that retaining the springs is where it's at. If your on a really tough climb, you can winch down your axle.
Retaining will balance out the front to rear, and restore order to the force.
j
Texican said:
OK, am I not seeing it?
Where is the rear of the top link attached?
Butch
Here's a pic of where the top link is attached to the frame. I chose to use a partially boxed mount with bolt going through the frame. This allows me to still drop the top link in and out to make adjustments quicker.
I'm leaning on the center strap because there have been way too many times where I am teetering on a boulder on the frame and my front wheels are off the ground completely. With both sides of the axle that low (10 inches down) the drive shaft starts to really slide apart and from my experience watching other trucks do this the shaft gets pretty week as it slides more and more apart. I've seen buddies completely seperate theirs and some even broke. When one wheel is up and other low I get my flex and it helps keep my driveshaft from sliding out too much.
I don't see any problem with using a center strap and trying to retain the springs in place. It's just with these 6" slee springs I'm not sure how much (if any) length I can get them to stretch. I don't mind them hanging there like they are now. But I am going to retain the springs at the bottom for sure..just in case they slip out while it's hanging there.
Thanks!
they'll stretch, it's fiziks.
I had 5" springs on my rover, and I still maxed out 14" shocks constantly.
Last Picture(s) I Promise
RTI pics... Here you go.
Clearance much better now :doh:
More pics here:
http://actionjackson.com/cruiser/trailrun.asp?TrailRunID=41
I'm going bananas about this project. :bounce: :bounce: :bounce:
Thanks for everyone who gave me advise along the way. It's definately time to wheel this beast again :cool:
Very nice job Shawn... very nice indeed...
Have fun with it!
-Matt
droop limiters on the front will be a must, and shocks with good compression valving are a must with this set up, because the car can get hooked up on the huge front droop, and going steep downhill, the car can literally "trip" over itself, if it has some momentum, and the shocks arent valved correctly on compression.
Especially if the front springs are unloaded out of the seat at that travel.
Sick!!!!
