Folks,
I have a 2003 LX 470 so the Slee tray cannot be used with the AHC being in the way. I used the space next to the AHC (by relocating the steering fluid bottle) for an on board air system. I'm considering using the space between the fuse/relay box and the brake system for mounting a second smaller battery. See picture below.
I can get a space about 8" by 7" by doing the following:
- relocate what looks like a vacuum relay or switch (see orange arrows). In the picture I've removed it and shoved it under the harness on the right. There is an M8X1.00 nut in there that can be used to mount it.
- re-locate the evaporator hose (red arrow). The hard line towards the bottom of this hose seems to be plastic. I'm thinking of cutting the plastic at the bend lower down (yellow arrow) and then getting a longer peice of hose to connect between the service port and the end of the cut plastic piece.
- remove and re-route the wire harness / plugs originally mounted on the Fuse/Relay box (green arrow). I think I can route this under the Fuse box. There was also a wire clip with two wires mounted next to the fule filter (purple arrow). I removed this and plan to mount it below the fule filter using the fuel filter mounting nut itself.
With this space I can mount an Odyssey P925 MJT battery sideways. The battery is 6 5/8" long, 7" wide, 5 7/8" tall. Mounting it sideways would give me space for two j hooks on the sides. Will need to figure out a way to bolt a flat steel or delrin plate on the bottom with some spacers to account for the uneven bottom. I'm hoping this battery will be enough for a couple of starts. Its only use will be as a back-up starting battery. I have a hellroaring isolator system from my previous car already installed.
Battery Spec:
Battery Spec:
- 925 cranking amps for 5 seconds
- 870 cranking amps for 10 seconds
- 765 cranking amps for 20 seconds
- 675 cranking amps for 30 seconds
- Short circuit current over 2400A
- 28Ah
- 52 minute reserve capacity with 25amp load
- CCA - 380
