Good work. I'm impressed a 2LT is pushing that hard up a 7% grade, but the 14.5 psi and sea level sure help. 5280' in elevation definitely makes a difference.
Personally, I still think if you are going through all this datalogging, all this performance enhancing, I would definitely put an EGT sensor PRE-Turbo to get the best idea. Heck even run 1 pre and post will give you tons of data on how much temp drop there is after the turbo. Yes, the hotter the higher thermal efficiency, but I wouldn't want to fly too close to the sun. You are measuring temps that are traveling down an exhaust pipe, obviously the closer you get to the cylinder, the hotter it will be. If you are trying to go 250hp thats probably going to take a bigger turbo and some tuning on the EFI part.
I don't think I have to tell you, but on older engines not designed for that power, the more HP you put to them, the less reliable they become.
I'll be watching, fun project for sure!
