4Ruster
2LT Sufferer
I have a 1986 4runner that I swapped a 2L1 non turbo diesel into. Runs fine (blue smoke on cold start), but I get very high EGTs when climbing relatively small hills and just trying to maintain 80+ km/h. It has a brand new 3 core radiator for a v6 4runner, and a 180 thermostat. I've mounted the pyro right on the exhaust manifold.
On idle it will sit at 250F
Normal city cruising (about 50-60 km/h) 400-600F
But on relatively small hills I'll downshift to 3rd to hold 50 km/h up the hill, not struggling at all, but the EGTs will creep up to 1100F, then the water temp will creep up to 195~F. Same thing when trying to go faster then 80 km/h on the highway.
The engine doesn't feel strained at all, and if I let my foot off the EGTs will go back to 600~F
The injector pump timing notch is eeeeeever so slightly above the notch on the timing cover, and the fuel screw as far as I am aware of, is 1/8th of a turn above stock. It never blows any smoke once its warmed for a few seconds after starting, you can just barely see a wisp of black smoke if you rev it, but you have to be standing right by the tailpipe to see it.
I need to decrease my EGTs when going up hills because I plan on taking it camping and offroading, and the hills to get out of the valleys are steep.
