SOLD 2f engine - Virginia Beach
Virginia Beach, VA
2F from an FJ60. Has a rod knock, but runs. Had good compression when installed. All cylinders were between 135-150. Has a rod knock though. All components will be stripped. It will be oil pan to head. That’s it. I’m keeping the water pump, distributor, starter, thermostat housing, fuel pump, valve cover and crank pulley $500.
What year model?
By the engine number it’s an early 84.
I think it is. It’s got a good head and I think the value is in that. If I were to keep it it would need a trip to the machine shop or a new crank. I have 2 other good 2F’s so I don’t need this one. It has a new oil pump and I’d let the valve cover go with it.
Are you taking the oil filter bracket off? I am in need of one with the sender unit port.
Thanks,
Mike
Bump
Sorry fellas, she sold.
