Mine did the same thing.I took it to a few places to diagnose.Someone said it was a rod knock and someone said it was a wristpin. It was to high to be the bottom end.I rebuilt it and now it dosen't make that sound.LOL
When you had the conrod bearing caps off could you feel any excess movement in the gudgeon pin [conrod to piston connection, not sure what you blokes call it]?Did you check for this on all cylinders? cheers
First thing that came to mind after the misdiagnosed #1 and #2 cylinder knock is likely a bad timing gear. The rubber insulation within the gear is shot.
HAHAHA! When all else fails, go overboard!
it looks like the camshaft timing gear was replace by a previous owner because it is a "solid" gear w/o the rubber dampener.
are you planning on replacing the punk-ass solid gear w/ the dampened one?![]()
