Wanted 2F camshaft thurst plate
ERNRAM
Austin Texas
Looking for 2F camshaft thrust plate. The one I have has some galling and the cam gear has lost alot of material. Got the engine from my brother that he got in a deal, so he never heard it running.
Thanks Ernie
It is all starting to make sense.....when tearing the engine down, the oiler nozzle should have been pointing toward the gap between the crank gear and cam gear. But it was not, instead pointing straight up in 12 o'clock position, so it was done wrong.
Therefore no oil was getting to the gear interface, and probably that same oil supply also feeds oil down to the cam gear/ thrust interface, which now was getting no oil.
The cascade was the relative motion of the cam gear to the thrust plate was not lubricated and therefore from the heat, the gear face wore away and the thrust gap grew and camshaft began to walk back and forth then damaging the back of cam and cam plug in the block
I would wager odds that the oiler was screwed in too far, and it pushed the timing cover plate (and thereby the cam thrustplate) forward into the cam gear.
I have a bin box of thrust plates for anyone else who wanders into this thread. I won’t waste my breath offering you one.
