Wanted 27 Spline - Worn Ebrake Drum for a 79 FJ40
Oklahoma City, OK
I ordered the TSM disc parking brake setup, and found it will require the 27 spline flange to mount the rotors. Seeing that the drum will be removed and only the flange will be used, I am hoping that someone with an old, worn out drum is looking to score some $$$ for the scrap. Thanks!
I think you might have some of the numbers/info wrong here. Are you putting a TSM disc brake on the back of your 1979 t-case? That drum only comes in 10-spline. The split case had a 19-spline drum.
Or are you doing a disc brake conversion on the rear axle? In that case, you do not need 27-spline axle shafts since the caliper bracket attaches to the rear housing flange. I'd suggest replacing the outer axle seals and updating the drain & fill pluig while you're in there.
We stock all these parts.
Georg
Valley Hybrids
