- Location
- United States
$2000!!!!!! My 80 needs a trans job..
This is a repost of my original add. I didn't know I couldn't change how the title appears on the FS page so I didn't want people thinking it was still $4000.
I purchased the truck from a local member thinking I was going to wheel it often but a recent move has shattered those plans.
The only reason I have to get rid of the Pig is because I need a DD. I have a FJ80 for wheeling and sadly need to sell her. Trades considered.
Has dents and rust so not a candidate for a restoration project. She is a good, solid toyota.
1972 FJ 55
1977 2F rebuilt w/ less than 1000 miles, 3fe headers, new water pump, oil galley plug, new rings, bearings, and gaskets,etc
1976 front disc axle
4spd transmission and *ithink* 3-spd case
NEW clutch, TO bearing, etc Machined flywheel at same time
SOA setup with 3'' body lift; yeah its a big pig
35 x 12.5 BFG MT's on 80 series wheels-- tires need replacing soon
Saginaw/Scout power steering (pump needs reseal)
GM high output ambulance altenator
IPOR sliders welded to the body
IPOR rear bumper w/ swingout
IPOR front bumper
Welded rear diff, I will include an open third member
ALL new Front leaf spring bushings, 0 miles
Chattanooga cruisers conversion van power seats
All new fluids with less than 1000 miles, including full brake flush
Cold Air intake
*the winch you see in the picture us not included
Truck is located in Beaufort, NC. Come for a visit, its a beautiful place!
I will post some more pictures soon.
Feel free to call or text me 919-219-fourthree0four- Kevin
OK, so known issues:
-It will need a more permanent exhaust solution, currently I'm using flexpipe and two mufflers from Jegs. Its fine for the time being and not super loud.
-Rear window motor is shot
-I pull the rear door handle too hard and broke the plastic
Q: Could I use this for a DD?
A: I have for the past 500 miles, its not bad.
Q: How is the rust on the frame?
A: There is surface rust but the frame is solid. Maybe the PO will chime in to second this
Q: How is the body?
A: There aren't any 100% straight body panel but she is NOT a raisin
Q: Does the air work?
A: Heat works great!
More pics: https://forum.ih8mud.com/vehicles-t...-wheelin-pig-fj55-w-new-2f-4000-trade-dd.html
1972 FJ 55
IPOR front bumper
Cold Air intake
Q: How is the body?
