87 4Runner 22RTE (turbo)
Was idling across the parking lot when the engine died for no reason. Crank, crank, crank... sounded like a no spark issue. Checked. No spark.
Went to get a meter, tried it again for giggles before checking the coil, etc... Thought I heard a clunk or two. Pulled the distributor cap - rotor was not spinning. Pulled the valve cover, chain is tight, but cam/chain not spinning when cranked.
Let's not talk about the Toyota "Specialty" shop which assembled my motor and screwed up just about everything else they touched on the truck. 22K since they worked on it, doubt I'll see much satisfaction.
Manual says I need to pull the head to remove the timing cover to get to the crank cam chain gear - any shortcuts? I'm also worried that the oil pump drive gear seems to be right next to it.
How garbaged should I expect things to be? Should I plan on another rebuild at this point?
