Word
to allIt's the contact in the solenoid. Just as I'm sure was expected. The poor continuity on the lead from the battery turned out to be the limit of the multimeter I have (when you touch the probes together, it reads 0.6 ohms of resistance)
So now we just need to read a bit more and see what the part number for the contact is, and figure out if we can get one through the dealer.
Thanks for all the help Ray and others, Wristy we'll follow your tips for making sure the contacts are adjusted right when installed. Bogo, thanks for the tips on removing, I picked up some extensions before heading over, and I don't think we could have got it out without them.
to all
I've seen that multiple times. Does it have a zero function?
First one I removed without the long extensions and it was a bitch!!! Then somebody here on MUD mentioned using long extensions. What a difference. Made it nearly easy. Only hassle was getting the nut started when putting the starter back on.
Given how old the vehicle is and if you have the $$$, I'd seriously consider changing the battery cables. I'd replace them with 2AWG or 0AWG cables. It will then start with a much deader battery.
i have 1/0 locomotive cable ground from the batt. to the block. and 4/0 locomotive cable to the starter from the batt.
