2021 LX/LC has different brake pad part numbers?
Northern California
My 2021 LX rear brake pad has only 2mm left after 30K miles, so I was planning to replace it with TRD brake pads and hoped it would last longer. But when I searched the part number, it turns out 2021 LX/LC has different brake pad part number than the other years. For example, the rear brake pad 2021 LX/LC is 0446660161, while others use 0446660160. I understand the TRD brake pad is compatible with 0446660160, but not sure if it's compatible with 0446660161. Anyone knows if there's any real difference between 0446660161 and 0446660160?
I get like 50-60,000 miles on my brakes? My mechanic puts these on Adaptive One Coated Premium Brake Rotors Adaptive One Premium Ceramic Brake Pads
TRD pads will bolt in to any US-market 200-series. Yes the 16+ LX/LC got larger rotors but the pad dimensions are the same, I'm running 08-15 pads in my 16+ calipers/rotors.
Lexus likely specified a slightly different compound for the 21 LX, to explain the part number change.
