2011 Land Cruiser Rear tail light bulb size
USA
Hi
I have one of my rear tail light bulb is out on the far right side. Not sure what type of bulb it takes and how do i get to it so i can remove it
Thank you
Aren’t they LED?
Regardless if it’s the housing attached to body you remove the two screw exposed under the hatch and pull out. There is a clip that you need to disconnect by pulling.
If it’s the lens attached to hatch there is a trim piece along the hatch that starts near the rubber bumper. Unscrew and you can access bolts that hold that assembly on
Aren’t they LED?
It weird im not even sure if the 2011 LC tail light bulb is led or not . I just noticed it wasn't on at first I noticed it sort of flickering and then it all of sudden now is out. Do you know what type of bulb it takes ?
ITs the tail light on the further right not on the hatch
Thank u
superbrightleds.com has a nifty tool that will tell you all the bulb types in a vehicle. It reports that the 2011 rear brake lights are "not serviceable by user". So that means they are LEDs integrated into the housing, can't be replaced.
