2011 HVAC DTC 42 & 48 Codes / Passenger Vent Not Blowing Strong
Phoenix, AZ
As the title suggests, my front passenger vents are not allowing air to be blown strong. I turn the climate settings from Lo to Hi and all vents throughout the truck increase in air flow - except for the two front passenger vents.
After running the HVAC self-diagnosis, two codes are returned: 42 and 48.
I’ve read a little on 42 being about servos, but can’t get much on DTC 48.
Tried pulling some of the HVAC fuses and they looked fine.
Also checked my cabin air filter and it’s fine. Even ran the hvac without a cabin air filter to see if that’s the bottleneck. Same result- passenger vents aren’t blowing strong like the rest.
Perhaps something is keeping the air from coming out those vents. Maybe it’s a servo.
it’s possible it could be wiring, connection, some circuit board, or some motor. Am just guessing at this point - and appealing to the experts herein.
Thanks in advance!
Same problem and question but in a 2016. No codes. Add mouse damage to air cabin filter.
Had a similar issue…is the air cool or cold?
My issue ended up being the compressor. Lexus dealership let me buy the parts and they installed. They installed new compressor, clutch and drier.
Interestingly they went trough at least two compressors I know of. They had my rig for about 3 weeks with techs trying to figure out the issue after the install.
Apparently, the magnet on the clutch was installed backwards and was causing a polarity/power failure on the system. I didn’t see the part but was told that there were no markings that indicated correct side for the magnet. All is well and they were gracious and apologetic throughout the ordeal.
I'm having this exact issue on my 2011, I even ran the Servo initialization sequence with my Creader scanner tool to no success. Anyone else get this resolved besides @mikesean76 without having to replace the compressor? If the magnet on the clutch is installed backwards as a possible issue, would it be possible to reverse the magnet myself?
B1442 – Air Inlet Damper Control Servo Motor Circuit. This is the one that controls the fresh/recirc door. You can replace it in place, but it's a tight space to work in.
B1448 – Passenger Side Face Servo Motor Circuit. This appears to have to be replaced with 2 others at one time. I don't know if they are easy to access without removing the entire assembly under the dash passenger side.
Can’t separate the blower unit on the right from the central air dist box with the dashboard in place.
