2009 LX570 HVAC help (1 Viewer)
Arkansas
I’ve searched high and low to see if anyone has had similar problems that I’m experiencing, but no dice. I’m hoping maybe yall can point me in the right direction.
About 2 years ago my LX started not remembering the last temperature and fan setting that it was at when I turned it off. After a few months I started investigating what might be the causes, and a common theme is the recirc door being broken, well I had not had my filter replaced and when tested it seems to work fine. I’ve replaced the filter twice and checked the door function and it appears to still be working correctly. I was content to live with this annoyance, but earlier this year the passenger side stopped blowing hot air. Not long after that the driver face vents stopped blowing as well. I’ve used techstream to reset the servos multiple times with no change. I just pulled the codes again today and they are B1441, B1443, B1445, & B1448. I’m assuming I’ll need to replace a servo the passenger side, but I wanted to try to get some feedback before throwing parts at the problem.
I’d say pretty low. A quick search shows it’s rare in the 200 series. If it’s easy and cheap, I suppose you could fire the parts cannon and try one. There’s probably a test procedure for the amp in the FSM?
Well, it appears as though the servo that controls the foot control on the passenger side gave up the ghost. I can see the other two servos move, and after removing the foot control servo I was able to manually open the vent that directs air to the feet.
After messing with all of this and initializing the servos through techstream about a thousand times the heat control has also started to work on the passenger side again.
My plan is to buy a replacement servo and replace it. Luckily this is the easiest servo to access.
I also managed to run the battery dead while messing with all of this yesterday and had to charge it overnight. Not sure if it’s connected but now the brake, ABS, center diff (flashing), 4lo (flashing), and AFS OFF (flashing) has come on the dash. The ABS/VSC/TRAC system is unresponsive in techstream as well.
I'm getting B1448 with very low airflow on my passenger side front now a couple weeks after I re-aligned my recirc door arm. How much of the dash do you need to remove to see/get to the 3 servos? Would you happen to have part number(s) of what you replaced?
