- Location
- United States
SOLD 2007 Husaberg FE650 1 owner super sweet!
SOLD
I bought this new in November 06 so the bike is still under warranty. I changed the oil after every ride. I use Motorex oil. I just had the suspension redone by Dick’s suspension; you won’t believe how good this bike handles now. I weigh 170 and weigh 200 with gear. Don’t let the 650 scare you away, with the titanium Akrapovic pipe you can go from mild to wild with the tunable insert. It handles singe track great and will go full out in the desert no problem. My wife rides a 2007 450X and this bike weighs 5 pounds less than her 450. The bike cost $10,550.00 out the door. Here is a list of things on the bike. Needs nothing, Ready to RIDE!!!!!!!!
I can deliver from Az to Ky along I-40 the end of September if needed.
Priced to sell now @ $7850.00
1) Renthal handle bars black, grips
2)Dicks suspension, with APS mod $950.00
3) Scotts dampner tower, just ad dampner and go.
4) Radiator braces by BOSS.
5)Scotts cleanable oil filter
6)Scotts shark fin
7)Akrapovic Ti pipe
8)Heat wrap to prevent burns
9)stock gearing with lower gearing =2 sets
10)Cycra hand gaurds
11)Trip master switch to control speedo/odo/hour meter/lap timer/ ect.
12)Air filter cover to seal hole when cleaning filter
13)Just adjusted valves, oil change, air filter clean, chain adjust,
14)Coolant changed
15)Power now in carb
16)New Guts seat cover, Kevlar sides to not wear out with knee braces, big improvement.
17)Heavy duty tubes front and rear
18)Rear brake pedal extender
19)KTM fork seal savers
20)Street legal Arizona clean title
21)Rear brake light switch installed
22)Relocated CDI box for running extra sub tank, hold almost 1 gallon 100 mile range
23)Balanced tires
24)Reusable valve cover gaskets along with stock ones
25) new spark plug
26)Comes with stock exhaust, hand guards, gearing, fork springs, owners Manuel, spare parts book, rear sub tank, total of 3 air filters, tool bag, handle bars, water pump shaft seals (new)
SOLD
6)Scotts shark fin
7)Akrapovic Ti pipe
14)Coolant changed
23)Balanced tires
25) new spark plug
