2002 LX470 Roof Leaking (1 Viewer)
Awesome, thanks! That’s a cool little camera setup you have, what is it?
Yea it was pretty sweet. It was a $15k borescope I was testing out for work. It was just a bit nicer than the cheap one I had picked up from Home Depot.
If you pull the interior panels around the rear windows on each side you can see the clear tubing pretty clearly. If you do that and pour some water down the lines you should be able to see it draining.
Here is the view of the rear drains. The video is upside down unfortunately. I don't recall exactly where the front drains, but it is somewhere near the front wheel (either before or after).
That's awesome. What diameter scope did you use?
