(I also posted this in the Mud Tacoma forum, but as it had not seen much action, I will try here too).
I am looking for some knowledge about my daughter's 2001 Tacoma (3.4, auto, DBL cab, rear locker, 4x4, 169k, no engine or transmission mods).
Backing up from initial start up is fine, but it does not readily engage the fwrd gears. It actually creeps fwrd slowly, but no change in rolling speed with increased engine rpm. I can run the shifter through Drive, 2nd, low, neutral, and no change in the end result. It will eventually catch with an audible, palpable, bang. Then fwrd progress is normal for a while.
No change when vehicle is hot vs cold. No change when it is garaged vs out in the cold (low teens *F)
Tranny fluid is older, but at the appropriate level.
No check engine or transmission lights on the dash.
If I jack up the rear end, both tires off the ground, and the TC and transmission are both in neutral, I can spin either rear tire fwrd or reverse x2-3 revolutions before the drive line binds up.
I am thinking this is a transmission issue; perhaps a valve body is stuck? Besides looking for disconnected plugs, what should the next diagnostic step be? Is a transmission flush worthwhile? Maybe freeing up debris in the mysterious inner workings?
Other thought (less likely) is transfer case. Again, 2wd-4hi-N-4lo: shifting is no issue.
Input appreciated!
Input appreciated!
