Hi guys, I am having an issue with this truck not engaging transmission in drive. Customer brought this to me in this condition, fluid was the consistency and color of chocolate milk. Low works, 2nd gear and Drive do not until you attain 10MPH exactly, then Drive engages and truck shifts normally. One DTC is set "P0770", in my research I cannot confirm this code should be causing this issue. Here is what I have done:
Drain and refill 3 times, fluid is now normal color.
Filter has been changed.
Trans. solenoid SL has been replaced with factory part.
ECM swapped with known good.
All wires pertaining to transmission control have been traced and continuity verified. Solenoids, speed sensor, TPS etc.....
Speed sensor replaced.
Manual shift test per FSM performed and passed.
Valve body removed, split and thoroughly cleaned, all valves move freely.
I am nearly at my wits end with this one. Long since stopped recording the hours I have put into it. I just want to give this guy a working truck back. Any and all help would be appreciated, somebody else must have run across this issue in the past.
Thanks, Steve.
Thanks, Steve.
