2000LC Cat shield Vibration ??
Discussion in '100-Series Cruisers' started by rtyson, Jul 5, 2005.
  1. rtyson
    rtyson
    14
    Aug 17, 2004
    :eek:
    Hello All, I've been reading many posts at this forum. I think its very informative and just darn interesting and pleasurable to read. I have a 2000
    LC with 74Kmiles on it. I purchased it last year in Nov for $25K (61Kmiles) which also included a 100Kmile limited warranty/Certified Vehicle. The truck was and still is in excellent condition.
    My question pertains to the vibration noise supposedly coming from the shields on the catalytic converter. I viewed the pic showing the fix for this vibration
    problem but after crawling under my truck I do not see these heat shields where
    the high-temp liquid gasket material would be placed. I do not see these shields
    running along side the cat, I checked both sides. But the vibration which is only
    present when accelerating from stop is quite evident.
    Has anyone made this same fix on a 2000LC, I noticed that 1999LC was actually
    shown for this fix.
    Rick
    InMissouri
  2. Jukelemon
    Jukelemon
    2,396
    5
    Dec 29, 2003
    Louisville, KY
    I do not think they changed the exhaust so either someone has taken them off OR you are looking at the wrong thing. Snap a pic and post it up.
  3. rtyson
    rtyson
    14
    Aug 17, 2004
    Thanx for response, I will double check underside and possibly snap some pics for posting if I still can't find them.
    InMissouri
  4. rule303
    rule303
    186
    Apr 29, 2005
    Cumming, GA
    The shields almost look like one single shield. Tap them and you'll hear the vibration. I put a large hose clamp(5" I think, maybe 7") around them and tightened it a bit and I no longer have any vibration.
  5. rtyson
    rtyson
    14
    Aug 17, 2004
    Sorry I have not reposted yet, I have not had a chance to take a second look underneath my truck yet and possibly take some pices. Working out of town (MI) does not give me much time at home right now but I will get to it. Although I did have my wife take the truck in for service at the Toy
    dealer. Besides my routine service at 75Kmi the dealer was aware of the TSB-Heat Shield Vibration
    and called to inform me that it would be $250 to replace the heat shields. Is that the 'fix' they called out in the TSB, I should have asked him that but needless to say I told him no way.
    InMissouri
  6. rule303
    rule303
    186
    Apr 29, 2005
    Cumming, GA
    Just clamp them and save the $250.
  7. cruiserheadrat
    cruiserheadrat
    120
    Oct 18, 2005
    Boston
    I had the same problem when the honeycomb on the interior of my right hand cat failed. I ended up replacing the cat. The OEM's are a bit pricey I went to an after market
