- Location
- United States
Today I am listing my 2000 Toyota Land Cruiser for sale, with a little under 185,000 miles I'm asking $11,250 OBO. I have had a car for about 6 months now and have enjoyed every second driving it. However with premium gas beginning to go over $4.00 a gallon it's time to sell the Land Cruiser. Major preventive maintenance was done a day after I purchased the Land Cruiser (about 5 months, 5k miles ago) and some was done there after. All work was done at SD Trux, a highly recommenced and praised independent Toyota mechanic. Brand new BFG All Terrain T/A KO2 (285/75/R16) were purchased on 4/19/2018 at 182,971 miles. I have documentation of everything done to the Land Currier. The car has been a southern California car its whole life and has no rust.
Here is a list of the preventative maintenance done on 1/25/2018 at 180,081 Miles
-Replaced timing belt, timing belt idler bearing, tensioner bearing
-Replaced water pump
-Replaced leaking valve cover gasket set
-front and rear differential gear oil drained and replaced
-Transmission fluid drained and replaced
-transfer case fluid drained and replaced
-Engine oil change
-brake and power steering fluid system replaced
-Replaced spark plugs
-Replaced sperpentine drive belt, belt tensioner bearing
-Replaced coolant
-on 05/02/2018 The front and rear shocks were replaced with stock shocks.
-on 6/05/2018 an oil changed was preformed
Mechanically she runs great and I have never had any issues with her. Cosmetically speaking the Land Cruiser is in pretty good shape. There are no tears on the leather, no smoke odor, its very clean inside. The head unit was replaced with a touch screen one. The paint is is pretty good shape, there are a few rock chips in front, the rear diver side trim piece has fallen of, thought I still do have it. There is also noticeable bush scratches on the passenger side of the truck. I have also removed the side steps, they will be included with the purchased of the Land Cruiser.-Replaced water pump
-Engine oil change
-Replaced coolant
