200 series body lift
@dmc can you provide a picture of the center console on Monica, if there is adjustment in the linkage for the shifter, then there may be a way to also do an extension, so I'll put that on my list to investigate..
anyway... wheels turning on future possibilities, on a 1 and 1.5" body lift... which is totally common in my other area I focus on....
The radiator looks pretty easy to get in place.. well with the right machined parts anyway..
I moved to Arizona a few months ago so to will be awhile before I can get back to Utah. But let me see if I can get someone else to snap a photo
Looks like the NST body lift kits are on backorder. Any other options?
I used a 100 series 1/2" body lift. I only had to modify the front-most body mount spacers by bathing them down to a size that would fit into the mount location.
If you go bigger, you will need new bolts at the second from front bolts (near driver/passenger foot-wells). The bolts that came with my 100 series lift kit would have worked, but i just reused the factory 200 bolts.
If you go more than 3/4", you will probably need to address the radiator shroud.
I am not aware of any other 200 series body lift kits. If I go bigger, I will get a 1" from NST.
