OEM alternators have served me well in four Land Cruisers thus far. Proactively replaced in the 2004 100 at ~ 180k. Proactively replaced in the 200 with ~120k with when the radiator was out.
Even with running a secondary house battery, the 180A output of the factory alternator has not been found to be lacking. The largest DC-DC chargers only pull 50A, well within the output range of the OEM alternator. There may be cold-weather situations were seat heats, defrost, fans, etc. are pulling a high load with insufficient amps to push to the house loads. If this is the case, a proper DC-DC will bias to keeping the vehicle battery from draining.
If the SBC is truly pushing an additional 240A I would take the time to ensure the wiring, connectors, fuse, etc. can also accommodate the same.
Aftermarket alternators may offer the promise of improved output yet without the proven engineering of factory. Perhaps they'll outlast your ownership. Perhaps they'll fail at the worst time and leave you stranded. While enthusiasts have high desire to chase 'better', there needs to be a tangible gain to offset the risk. In my experience, I've not seen any cases where additional amperage would be a real-world gain.
Factory is not an inexpensive part, but it's the way I would go. FWIW.
