For Sale 2 1FZ-FE engines and transmissions (supercharged)
North Carolina
SuperCharged 1FZ-FE complete Engine for sale. $6500 SOLD
Engine was rebuilt at 300K mile, bored 10 over with Toyota internals. has about 130K since the rebuild.
installed is a Kazuma/TRD supercharger with about 15K on it included are the 3" and 2.8" pulleys.
Included is a custom 7th injector setup for a a Toyota injector controlled by a Split Second AIC1-A2H Absolute Pressure, 2 Hi Z Additional Injector Controller
included a custom adapter for the fuel rail to supply fuel for the 7th injector.
included is a Split second LSC2-001 Universal Fuel Enrichment Module which influences the O2 signal going to the ECU to make up for the extra fuel.
you can also run this on a ODBII vehicle with or without the 7th injector and enricher. base fuel map included
included is the upper intake inlet nose from the TRD kit if you don't want to run the 7th injector/plate. (not pictured)
engine is currently in the 80. you can see/hear/drive if you like. no known issues.
have a pair valve relocation pipe set. (not pictured)
will include exhaust manifolds with O2 sensors and 95 style magnaflow y pipe.
most all hoses and sensors have been replaced with toyota parts.
Spare (on the engine stand) 94' 1FZ-FE longblock with almost 130K on it. i saw it in donor cruiser started and run no smoke or knocks. $1500
Toyota A442F transmission has about 15K on it with an aftermarket torque convertor (currently in the 80). $900
i'm keeping the Transfer case, everything is working/running as it should, i'm just evolving/mutating to an LS
all parts are in Raleigh NC. willing to put on a pallet and deliver to the local fastenal and ship it to you on your dime.
or even deliver locally within reason.
more info or pictures on request.
have the original A442F with about 415K on it, was working when i swapped out for the newer one during the SC install. (free to a good home)
included
Are you going to the Relic Run this weekend? I'm interested in the spare motor and would be cool to talk about it there
Interested in the one on the stand. I'm down in Southport and can pick up.
I will not be but more than willing to give me a call or text , 919-257-9948
1fz-fe w/ supercharger is sold
Do you by chance still have the VAF?
