So I have just purchased an 03 LX 470 and made my very 1st mod. (Here are some before and after photo's). This rig came with the 20" rims (for sale) and I went back to an 18" stock wheel with the 285/65/18. Next in line is the ARB Sahara bumper. I think this is the only one that will fit the 03. I also don't think I can get a winch with the weight on the height control. Let me know what you guys think!
every noob gets told to loose the running boards. Let it be their choice, its kind of annoying to not have them unless you have the dough for the step sliders ready.
Keep us posted on your thoughts on those E load BFG ATs. I'm tempted to do them in a couple of years when I need new tires, if the on-road ride's not too bad.
Depending if you plan to go off road or not, you may want to look at sliders before a bumper. Just a thought. Unfortunately there is never enough money to do everything you want at once!
Just a little feed back on fitting a winch with AHC. FYI - I kept it light by going with a TJM T3 in front. Not sure how much lighter this is than an ARB Combo but I'm guessing it weighs about half as much. Also went with a Competition T-Max 9000 Winch with synthetic line. It only holds 80 ft of line, but I keep another 75 feet in the truck. Total weight for the winch is under sixty lbs. vs over 100 for a Warn. We'll have to see how it holds up in the long run, but the rated pull is quite high. I figure I can always use a snatch block to up the capacity. So far no problems with the AHC - even with a loaded truck.
