I can't say I know the kzte but I put an oil bypass filter on my 2h. A local fellow lathed aircraft aluminium into what is called a sandwich which fits between the oil filter and oil filter housing with an extended threaded spindle. It has something like 2x npt outlets and a bsp one. From the sandwich a hose leads to a filter housing which holds what looks like a fancy toilet roll. I use the other two outlets for an electrical oil pressure gauge and another for a mechanical oil pressure gauge. Oil return goes through the filler cap, so you can change oil whilst the car is running if you wanted. For a period I would remove 200ml and top up with fresh oil, but then you have sump oil to deal with. Some put it into the fuel tank but I hate to think what it does to injectors.
I like the concept, apparently the germans wanted to get from europe to argentinia without having to stop for oil changes in submarines after wwii.
Been running it for about 180k kms, installed it at 180k kms. But, due to adding extra opportunities for oil leaks and or weeps, sometimes I wonder if it was worth the set up. Every connection, every o ring..
But it has done ok for about 5-6 years now. The oil still gets dirty of course, it must help but I don't have another engine to compare to without a bypass. My rear main oil seal needs replacing and I probably should put some fresh injectors in, valve seals would be good to freshen up to...
I get average of 10km per liter, so pretty happy on the freeway, 90kmh, 2-2100rpm. I have not heard of many getting such fuel consumption , so maybe it helps. Best is 8.9l for 100km, in a troopy, light load.
I gave a happy rave about it when I first installed it on mud, thought I was real clever. But there is nearly always something else on old cars. Most trucks have oil bypass filters, the early 2h even came factory with an oil spinner.
The combo of oil spinner and bypass filter is meant to be the ultimate, which is a major investment which could buy copious amounts of oil. Nothing beats fresh oil. Some folks change oil back to back 3x to clean the internals without fancy chemicals.
I still change my oil every 5k kms regardless, always stocking up when 10l is on special. Oil is cheap in the world of motor maintenance. One of my friends has over 600k kms on an 80's hilux, petrol, country miles only, so it says a lot for 5000km oil changes.
There are a few mobs like amsoil, frantz, which sell kits especially in the states, probably for your engine if you hunt around. Some have the return line going to the sump. I have jackmaster, he lives down the road from me, but he is a one man show and was ancient 6 years ago, very clever fellow.
Grand scheme a point to note is if the initial investment will last the life of the vehicle, rust, other major parts or an accident ride off.
I am building a second 2h, it has the sandwich, as I love accurate oil pressure readings alongside temp of coolant, then I can turn the tunes up. But I baulk at the cost of a bypass filter now a day, probably 3x what i paid initially. Handy to get enough filters for it, orings etc to last a million kms too.
If money is not an issue go for it. Could just buy a lot of oil and change very frequently too. It did seem to work better initially, but it may be my injectors.
