Hi guys
I am now in Argentina and the car is again starting to overheat often.
I really thought I had the problem solved in Ecuador, but it seems that it's back again and this time I am really out of ideas!!!
Story:
I started the trip in 2012, about 100'000km ago in Canada and up to Mexico I could drive the car from ocean to 4000m on steep hills and it would never see more than 100Celcius oil temp! Watertemp I don't know, I had the stock gauge back then.
In Central it slowly started to get hotter when climbing hills, but was still ok. In Ecuador it was so bad, that it reached on regular hills 130Celcius oil and 110+ water and smoked out of the overflow bottle!
Changed everything, did not help. Changed the injectors (80k old) and it ran much cooler! I thought the problem is solved. Now I am again back to having problems...
Maybe some of you still have an idea?
Here again the facts:
Car: HZJ75 with about 3.6-3.8 tons, depending on water & fuel.
Engine: 1996 1HZ engine with about 200'000km. Rechecked valve lash about 25'000km ago and it was at max. end play on all valves.
Turbo: All American Turbo, about 100'000km, 8psi boost. Oil cooled.
EGT gauge: can go up to 700Celcius PRE-Turbo, but I always keep it at 550Celcius max 600Celcius constant temperature
Injectors: rebuilt set with Denso parts in Peru about 5'000km ago
Injection Pump: rebuilt about 80'000km ago at Fred Holmes in Vancouver, Canada.
Installed a boost compensator and adjusted the fuel delivery to be slightly higher than stock 1HZ due to the Turbo. Not touched since then!
Injection timing: I set it 15'000km ago to max. value as specified in FSM. That means max. advancing within FSM spec. (I think that was around 1.09mm or so)
Thermowax works fine, I just checked again and when hot it is all the way out.
Fan clutch: I just put 2 bolts through it! After removing it 6 times I was sick of it and thinking that it MIGHT be the fan clutch so I fixed it now to 100%!! Helped ZERO!
Radiator: australian northern radiator, 4 row brass. s*** quality, had to remove it 4x already due to leaks, but 15'000km ago it was completly open at a radiator shop and the guy said it looks new inside. Radiator cap about 30'000km old, japanese made.
Shroud: stock one
Radiator hoses: stock Toyota. Bottom one reinforced with spring inside, just to be sure.
Thermostat: 15'000km old, new Toyota installed.
Waterpump: 15'000km old, new Toyota installed
Timing beld: 15'000km old, new Toyota installed
Coolant: always Toyota RED in 30-50% concentration, depending how much coolant I loose due to overheating or radiators leaks. Top up with destilled water.
Checked coolant for acid 15'000km ago when it was overheating hard and it was neutral.
A/C: stock setup, although does't run when having overheating problems, but the cooler surely doesn't help airflow!
Brakes: checked again, don't overheat! Free spinning wheels
Diesel: right now 500ppm sulfur in Argentina and what I read about 46 Cetane.
Bad things:
Winch in front of grill
bug-mesh on front grill
A/C cooler in front of cooler
missing hood rubber seal that seals between hood and radiator support
Here a few driving setups of the last few days where I went offroading in 3000-5000m altitude!
Very low tire pressure, gravel road:
Going uphill, 60kmh, 3rd gear, 2500RPM at about 4000m elevation
EGT 550Celcius constant
Air temp about 30Celcius
Oil temp 105Celcius
Water temp 95Celcius
Flat, 80kmh, 5th gear, 1800RPM at about 3500m
Air temp about 28Celcius
Oil temp 93Celcius
Water temp 85Celcius
4000-5000m uphill, 2nd gear, 2500RPM
EGT 500Celcius constant
Air temp about 5Celcius
Oil temp 100Celcius
Water temp 80Celcius
Today at 1500m, with high tire pressure and at 60-80kmh and 20Celcius ambient temperature I only read 72Celcius water temp and 91Celcius oil temp. It did feel pretty ok again as it should be!
So my questions here are:
HOW can altitude affect my setup? Can it be the reason of overheating?
If yes, what should I adjust or change on injection timing (I got the tool with me!) or fuel delivery?
The temperature always increases very slowy... it takes about 10minutes at 25-30Celcius ambient (thank god I never had more!) till the oil and water slowly increases to a point where I stop, open the hood and set idle at 2000RPM to get it cooling.
BUT the weird thing here is that it takes MINUTES to get the water temp down from 105Celcius to let's say 90! We are talking of 5minutes or more of fast idling with open hood!
If I pour 2 cups of water slowly in front of the radiator it cools inmediatly down to 80Celcius!
WHAT CONFUSES ME HERE IS: if I start to go downhill, let's say at 105Celcius water temp at same 2000RPM, the water temp gauge decreaes within 20-30seconds down to 90Celcius, within 1 minutes it's down to 80Celcius!!!
If I do the same but in fast idle it will take OVER 5 minutes to get down to 80!!!
So in other words, the little extra diesel it injects to reach 2000RPM is somehow enough to keep the system overheating!? How can that be??? Is it maybe really a bad injection timing or fuel amount???
I did this test now many times, but usually at 3000-5000m altitude.
Also, can it be that the Argentina Diesel with 46Cetane increases overheating? I bought some Cetane booster, no idea if it will help, but still need to try them.
What about Turbo aging, does a Turbo generate more heat into the oil when getting old?
I measured with an IR sensor at the entry of the radiator 88Celcius when it was at medium temperature idling at slow RPM. When I increased the IDLE to about 1500-2000RPM I saw the radiator inlet temp increase within about 1minute to 91Celcius! Is that normal??? I would think the higher RPM let's the fan turn faster and cool down more? Why does the water temp inlet increase instead of decreae?
I will get a heatsink oil cooler and check tomorrow for a very thin pusher fan in front of the radiator.
There is only very small space between AC cooler and front grill support!
BUT this are all band aids to a problem I didn't have 1 year ago! Why is it suddenly having so big problems?!
I am super happy for any ideas! I really fear to damage the engine and there are still quite some high passes in front of us going down to Patagonia!!
Thank you!
Story:
Shroud: stock one
Bad things:
Oil temp 105Celcius
Oil temp 93Celcius
Oil temp 100Celcius
Thank you!
